Built-in = drawers issues|Forum|WOOD DESIGNER
Andy Brown
Forum Posts: 17
January 18, 2024
February 19, 2024 - 9:03 am
Hi Alex
Thats worked
Forum Posts: 1964
February 19, 2024 - 7:46 am
Can you upload your cabinet? to be sure of my answer
But in first view, If you have maderecess from front, you should applied similar slack in depth on your drawers
drw-bin.pngImage Enlarger
Andy Brown
Forum Posts: 17
January 18, 2024
February 16, 2024 - 3:13 pm
Hi
just a question on inset draws, is there anyway to get the draws to be inset so on the attached image i need the draws to follow the fixed shelf. this is because there is a full height door going on and need room for the hinges and these doors are push to open
Screenshot-2024-02-16-150956.pngImage Enlarger
Forum Posts: 1964
February 2, 2024 - 8:43 am
After adding your drawers you can edit drawers sub-method, for temporary editing well edit sub@cabname
Edit Slack from top on built-in drw, then Slack from top into assembly
scott powell
Forum Posts: 27
May 25, 2023
January 31, 2024 - 3:31 pm
thanks
when using the method of nil shelves, whats the best way to adjust the space in-between drawer fronts to allow space for hand
Forum Posts: 1964
January 23, 2024 - 8:14 am
When you using Blum applied = spaced drawers, they using rules by default ( Blum/drw-TANDEM/= )
This rules said at Polyboard need to look Overpassing frontage panel (drawers), and start drilling from frontage at 19mm
which allow you to work with standard bottoms of 19mm or less, but which reduce all the drawers above to be interchangeable.
equals.pngImage Enlarger
If you use this with built-in drawers, Overpassing panel become side and as Side haven’t go Surface split like drawers it only applied single fitting and need change rule to Underpassing
rule.pngImage Enlarger
But in case of equals Built-in drawers, The best way without editing rules is to use Nil division in use with Blum/drw/z method
scott powell
Forum Posts: 27
May 25, 2023
January 22, 2024 - 10:25 pm
when using the applied = spaced drawers, the holes in the cabinets side are correct
but when switching to built in = spaced drawers, the holes are not correct and also not showing on all drawers.
also the drawers start a lot further off the base of the cabinet
hope you can help thanks
Most Users Ever Online: 365
Guest(s) 29
brendan kavanagh: 179
Tom Cleaver: 164
mark nichols: 162
Conor Devoy: 158
Zaheer Abbas: 132
Blake Simpson: 104
Patrick Maylor: 84
Tom Jackson: 83
Rick48
Hassan Sultan
Carmela Di Sorbo
Telmo Oliveira
Jesus Vergel
eduardo beiza
lucas Lucas Moreno
Efthimis Stathas
Rayallie
Topics: 2513
Members: 393
