Cabinet Library|Forum|WOOD DESIGNER
OfflineHi Shafeek,
There are a significant range of kitchen cabinets and other projects in the “Models” folder that you might be able to use as a starting point for creating your own libraries.
However, as it’s nearly always necessary to set up libraries according to you own manufacturing standards, I would suggest that the first thing you do is set up the manufacturing methods and sub methods according to your construction requirements.
With the manufacturing methods set up you can take any model an applying the appropriate manufacturing method you will create an element you can then save as a standard cabinet.
If you need help doing this don’t hesitate to post your questions on the forum.
You might also consider buying some online training. In training sessions we set up your manufacturing methods, start making you libraries and show you the best way to use and organise them. As well as this as each session is recorded in your own video library you can use the videos to train other members of your team. In my experience, you can save a lot of time and avoid a lot of mistakes with just a few hours of training.
Training packs are available from our on line store here:
I would suggest a couple of 4 hours packs would greatly help you get everything set up correctly.
Hope this is helpful,
Hi ,
I want to create separate Libraries eg Vista Kitchen & Vista Wardrobes.
The team should be able to open the library and see all our standard Cabinets . They should be able to make the project by using those standard cabinets by changing to the required Dimensions. How do I go about it ?
Are there any ready libraries available which we can take and modify for Wardrobe cabinets ?
Shafeek
