Cabinet Position|Forum|WOOD DESIGNER
OfflineHi Grover,
Go to “Post Processors Options” > “Orientation” and click the 3 dotted options button. Set the “Orientation” to “Horizontal max.Dimension”.
This will turn parts so that the longer sides are horizontal along the X axis.
Grouped drilling is not created by Polyboard but by the CAM software you are using. BiesseWorks and Bsolid recognise when the holes can be grouped and lowers the drilling head accordingly. However I’m not sure for TPA and it’s possible that it doesn’t do this as I think it requires a specific code in the the pp file.
OfflineHi Grover,
What do you need to rotate parts for?
In the post processor options you can change how the parts are orientated in the pp export file:
In Polyboard you can only rotate cabinets in a Project, this doesn’t effect the pp export only the cabinets position relative to the project.
OfflineHi again,
Do you want to rotate parts in Polyboard or in the pp output?
OfflineHello,
I’m sorry but you question is not clear to us .
Can you explain more?
Are you asking about rotation of parts in the post processor ?
