Changing fitting links and 3D window|Forum|WOOD DESIGNER
December 16, 2021 - 10:23 am
Yes on my test have deleted your single panel fitting
single.pngImage Enlarger
and replaced by 2 inner tooling
DXF export
DXF.pngImage Enlarger
same setting 3ds export
3ds.pngImage Enlarger
December 16, 2021 - 10:08 am
Alex said
Sorry I made a post correction at the same time
Cheers, Alexandre
When I open inner tooling – it shows me only one inner tooling.
Do I have changed some settings?
I feel that I`m very deep in forest 😀 innertooling-1.PNGImage Enlarger
December 16, 2021 - 9:59 am
Cheers, Alexandre
December 16, 2021 - 9:56 am
Alex,
Please check one more time that file, it should not be like this :
Capture.PNGImage Enlarger
December 16, 2021 - 7:53 am
To be sure, ou can export with tooling
From menu Tools>Preferences> DXF 3D export
tp.pngImage Enlarger
In order not to have this, you must create a specific inner tooling and structure, for each drawer length,
Like you already have done, but adjusted in “width” for each inner tooling
Why did you use “inner tooling” for the interior sides of the drawer and a single panel for the exterior sides of the drawer ?
If used “inner tooling” that will no appears on dxf export to sketchup
innert1.pngImage Enlarger
innert2.pngImage Enlarger
Cheers, Alexandre
December 16, 2021 - 5:23 am
Please check drawer sides in this cabinet. – there are not necessary groove from outside.  why it appears? And how to make it to dissapear?
THanks.
December 16, 2021 - 5:18 am
Girts Martinsons said
Alex said
Please check this option
3dtooling.pngImage Enlarger
Or menu 3D > Toolings
All the best, Alexandre
Tell me please – how can I export project in 3D mode – so all the drillings are visible?
Thank you.
Thanks, I found the way how to export , and how to import with drillings.
But I have another issue.
The inner tooling for tandem drawers(if is used 18mm material)
Can you please help me out with creating correctly the tandem sides (there has to be groove 2mm on internal side, so the sides moves closer to center. )
I created inner tooling for that, but when I export dxf, and import it in sketchup – it is showing all inner tooling dimensions for drawes side bottoms.
inner-tooling-visible-in-3D-export.PNGImage Enlarger
December 16, 2021 - 5:01 am
Thank you.
December 14, 2021 - 9:24 am
Here attached quick Video,
December 13, 2021 - 5:32 pm
Thanks,
I will check later.
Could you please tell me –
When I`m making thickness split. and make –
Panel 1 – 18mm
Panel 2 – 4mm.
How I can make Panel 2 to be automatically smaller for 2mm in width and height?
Because in oversizing rows it does not allow me to create smaller with minus sign.
Thanks.
Guest(s) 42
