Fittings are define by default into Sub-methods fittings link
an example is provided with the QuickDesign libraries.
I'm not sure if I understood your request correctly, but I think I understood that it's about the link between the upright and the bottom.
Groove don't create fittings, and that why Polyboard doesn't understand
Hope this video helpful.
All the best, Alexandre
Jan Van der Heyden
May 18, 2014
hi Stefan or Ness,
We want to implement polyboard in our organization, but then a fixed method has to be programmed.
Attached is a .Cab file where I want to change the priority in the rules so that my fittings are milled into the bottom instead of the side. Is this possible? or is there a way where i can create a method where all operations and priorities are committed.
