Closet build in a free form wall geometry with recess areas.|Forum|WOOD DESIGNER
October 4, 2017
Hi, thanks for the tips.
However, I would like to make the left recess part separately and then have the two sliding doors (without notch) closet and then the 3 sliding doors closet.
That way, it would look aesthetically good. Customer would only have access to that left recess area only if he opens the left sliding door. The face of that recess area will be a fixed piece of melamine.
Thanks.
Hi ,
Please find on your DXF, the 3D cabinets of what I have in mind
From the photo, the left wall appears to be sloping.
I don’t mind the notch in the door, but it forces the position of the doors
Thanks, side is not inclined. In any case, a rebated door, like I suggested, would be a bit tricky and aesthetically not so good.
Alternatively, the left recess part of that closet would be a small fixed melamine-closed space and only the left side of that closet had to be cut to be united with that small space.
I attach the floor outline .dxf for reference.
Thanks.
October 4, 2017
Hi Alex, it’s been a year since our last meet.
What do you mean by doors being managed separately? Cannot be sliding doors?
According to your drawing, in the left 2 door closet, the left door can be made with a rebate in the upper left corner to follow the box and wall. In that case, that door could be a sliding one, right?
October 4, 2017
Hi, I would like to build a 5 door closet (2 sliding doors and 3 sliding doors) in a room with some non-vertical angles and two walls that have recess areas.
Please take a look at the photo to get an idea. The closet will be higher than the recess areas and my client would like the closet to exploit all the space available, including that one in the recess areas. Those areas’ height is 227cm and the ceiling is at 265cm.
Is this possible to be designed in Polyboard? Any info would help a lot.
Thanks.
