Corner kitchen cabinet|Forum|WOOD DESIGNER
Two way , first with double back, before vertical division to keep zone behind double back free for shelves, but this solution don’t work well for hing’s
and double back from frontage can be adjust after setting frontage and false frontage (double back)
The best solution is to work with free shape Mode! please look this video!
Sorry in the video I forget to change libs in EN version but you can select hing blum 79T959 Side / Door
Hope that’s helpful, Alex
May 3, 2023
Good morning
I am trying to build a corner kitchen cabinet as per the attached. I tried the L shaped model but cannot get it to do what I need. In the attached, I used a nil panel to split the face as I would like and then used a double back to create the fixed face panel, this then allows me to add a door. Using this method I get everything I need other than I cannot include a full length shelf due to the nil panel. Is there a way to do this as hinges now allow me to clean up the corner situation and I would like to build the unit as per the attached but would be great to have the ability to have a shelf that passes through the nil panel?
Patrick
