Creating fitting for kesseböhmer tandem|Forum|WOOD DESIGNER
You will find in the attached box my interpretation of the Tandem II height 1700 width 600
I’ve chosen to work on an internal zone, which allows me to ignore the X and Y overlap value.
I welcome any comments, and don’t forget to update the diameter and depth of the drills to suit your needs.
Heimwood APS
Forum Posts: 42
May 2, 2023
OfflineHi there
We use a pantry pull out system from Kesseboehmer quite often, and I thought would try and make a fitting that fits their templates for easier installation. Can I get a few pointers on how to best do this? The installation requires pilotholes on the sides, door and bottom.
Here is a link to the model in question: TANDEM II – Kesseböhmer Support Portal (kesseboehmer.world)
Kind regards
Oscar
Guest(s) 30
© Simple:Press —
