curved groove in panel|Forum|WOOD DESIGNER
May 25, 2022 - 9:43 am
I gave this example but if the drawing is done like this, in reality the outer curve should be 970mm and the inner 976mm, for a width of 4.21mm for 600mm long
if you use a 4 mm cutter for a 4 mm width, the drawing of the inner tooling must match perfectly.
Please find attached this curve into DXf you can importe into Polyboard closed curve ( or CAD sofware)
curve-1.pngImage Enlarger
brendan kavanagh
Forum Posts: 236
May 24, 2022 - 3:19 pm
No it doesn’t on the back??
Can you check the curve for me please?
May 24, 2022 - 3:05 pm
Yes,
Doors or back, it’s the same for inner toolings, now I presume it works with this news closed curve?
brendan kavanagh
Forum Posts: 236
May 24, 2022 - 2:31 pm
Hi Alex
I think i have done that now, i put on a door on the cabinet and it worked but we are not doing curve on a door its on panel measuring 600 x 400mm
if we wanted to just do the curve on a board with those measurements can we do that? i have sent the 2 different files for you to see,( i just made a cabinet and took off the sides top and bottom left the back i think that’s why it didn’t work before)
hope this makes sense
Thanks Caroline
May 24, 2022 - 7:58 am
Please check your curve, it is not 4 mm wide on the right,
I think you forgot one point, make a rectangle of 600x4mm for example and then create the curves of radius 970.
This creates an error as the tool cannot do the path, it may even have to do a 4.21mm thickness for length of 600mm
brendan kavanagh
Forum Posts: 236
May 23, 2022 - 12:12 pm
Hi Alex
Thanks for video i followed that and i think it has done the curve but when i put it through to Vcarve it is telling me to check tool not corresponding with vector
I will send you the files could you have a look what i did wrong, we will be using a 4mm router to make the curve 4mm wide and 4mm deep
Caroline
May 23, 2022 - 6:09 am
Hope this quick video helpful,
brendan kavanagh
Forum Posts: 236
May 19, 2022 - 4:57 pm
Yes like that Alex can you send on video please’
May 19, 2022 - 9:43 am
Something like this?
test.pngImage Enlarger
brendan kavanagh
Forum Posts: 236
May 17, 2022 - 3:41 pm
Hi
Not sure if this is right area to ask, see attached pictures we want to make a groove and curved angle in a panel 600 h x 400w 18mm board , the groove is 4mm deep and 4mm wide with an angle as shown in drawings
Hope the drawings make sense can you send me a video on how to do this
Thanks Caroline
Guest(s) 61
brendan kavanagh: 236
Emmanuel Sacco: 210
Zaheer Abbas: 201
Tom Jackson: 142
Rooms Made Simple: 132
MobLux
Valentin Zarzara
Kendal Anderson
Sarah J0hnson
Andreas Nygårds
Nicolas LEBRETON ROOST
Luka Savić
Lee Gent
A S Brighton
Tobias Briander
Topics: 3062
Members: 602
