Dimensioning project drawings|Forum|WOOD DESIGNER
I was just working through a tutorial video that covered the use of the horizontal measuring tool in a project drawing. The video shows how to make a dimension ‘permanent’ by right-clicking on the newly created dimension and selecting the ‘make permanent’ command near the bottom of the context menu. When I try to duplicate this, the command doesn’t appear. (The rest of the menu is there, just not the ‘make permanent’ command.) Has this been removed or is it only available in ‘full’ version of the software? Just checking.
Guest(s) 13
Topics: 3003
© Simple:Press —
Offline
