Door error|Forum|WOOD DESIGNER
When I look at your material style sub-methods, your doors default to 30mm, and there is only 27mm behind your drawers.
as a reminder, you usually need an extra 10 mm for the runners from the back of the drawer to the bottom of the cabinet.
either use 450mm drawers or a 578mm deep cabinet
Conor Devoy
Forum Posts: 174
January 28, 2018
OfflineHi guys,
I had drawn a set of wardrobes which had doors.
The client wanted changes, during this process I deleted the doors.
When I went to add the doors I got an error saying “the defined dimensions do not allow for drawer creation”
I’m attaching the file and a screengrab of the error.
Hope you can help.
Guest(s) 28
© Simple:Press —
