Door Hinge location|Forum|WOOD DESIGNER
Door Hinge location
January 12, 2016 - 4:14 am
Thanks for the advice. The fitting is now in the proper position.
Gabby
December 29, 2015 - 6:44 am
Hi Gabby,
As the left door is “built in” with the adjacent panel overlapping, it looks as if you will have to change the rule and the hardware.
To do this select the door and in the “link” to the left side select the “fittings”.
Change the hinge to a built in hinge and change the rule so that it references the under passing panel.
You can also set this up with a manufacturing method to happen automatically when the doors change priority.
Can post your Polyboard file s that I can take a closer look?
December 25, 2015 - 12:01 pm
Is there a way I can move the door hinge tool ( lower left) higher, aligned with the right side? I tried editing the rule properties ( Type: Single) from  for the hinge, apparently it appears to mirror the other door. The panel on the left is longer than the right and the distance of the starting/end points uses the shorter panel as the guide.
Gabby
door-hinge-location.JPGImage Enlarger
Guest(s) 25
Topics: 3003
