Door Sizing Error?|Forum|WOOD DESIGNER
Door Sizing Error?
Tom Jackson
Forum Posts: 104
August 17, 2023 - 12:44 pm
Of course the external zone was the issue! I knew it must have been a simple answer, appreciate the explanation here, it was very helpful! I recalculated based up on the updated measurements of 789 and it works perfectly.
Have a great day Alexandre
Cheers,
Tom
Forum Posts: 2091
August 17, 2023 - 12:35 pm
Sorry but I think you missing something,
your alcove measures is 2568mm, less 2 filers of 100mm 2568-(2×100) divide by 3 cabinets equals 2368-200 / 3 789.33mm round to 789mm
Cabinets A and have B measurement of 856mm less 100mm external zone zone respectively on left en right
A-C.pngImage Enlarger
The outside area is set on the inside of the cabinet reduced here for A and C to 756 mm, and B is equal to 865,
You may have already realised that we can’t supply equal doors,
If you want equal doors, you need to remove the External Zones on A and C and change the width to 789mm per cabinet.
edit.pngImage Enlarger
Cheers, Alexandre
Tom Jackson
Forum Posts: 104
August 17, 2023 - 11:35 am
Not sure why, but the door is shorter on a couple doors. This shouldn’t be the case as the cabinets are equal widths. Any ideas?Door-Error-.jpgImage Enlarger
Cheers,
Tom
Most Users Ever Online: 704
Guest(s) 100
brendan kavanagh: 198
Conor Devoy: 158
Zaheer Abbas: 152
Patrick Maylor: 108
Emmanuel Sacco: 106
Blake Simpson: 104
Nathan Bruton
Michael Okyere
Timo Pitkänen
jose andres durango medina
Dag Lislerud Midtfjeld
Rejmond Islami
juan cabezas
Michael Dyer
ALEJANDRO PALACIOS RODRIGUEZ
David Filiba
Topics: 2697
Members: 463
