October 21, 2020
Okay,
I understand now with your practice,
1* When you need to select in the Polyboard, it's always the same.
The first click for the zone, the second for the parent zone attached to the room, and the third for the entire cabinet.
2* If you add a panel, like a double back (and surface split) and change it to Nil, that panel stays here and locks the zone to be used.
3* This quick video shows you how to modify your current cab and mobile shelf to set the height of your double back, and not lock the area.
I hope this helps, Good luck, Alexandre
October 21, 2020
October 21, 2020
Hi Alex
Pictures too hard to attach, I cannot resize them. I have 3 zones in the cabinet, its a kitchen base unit with a door at the bootom and a drawer at the top. I can select each of the zones individually or all of the zones together. What I need to do is select the bottom 2 zones for my inset doors.
Dave
October 21, 2020
Can you Upload your cabinet?
All the best, Alexandre
October 21, 2020
Hi
I have a cabinet with a mobile shelf, recessed from the front which has a face frame. I am trying to add inset doors but I can't select both zones of the cabinet to apply the doors to the full height. The doors are applied either above or below the mobile shelf.
The cabinet also has a drawer above the area I am wanting to put the door.
Dave
