Drawers into a slope top cabinet|Forum|WOOD DESIGNER
June 30, 2018 - 9:32 am
Sorry, no other way for the time being.
Cheers,
mark nichols
Forum Posts: 169
sp_UserOnlineSmall Online
June 28, 2018 - 3:47 pm
Hi Ness
Yep, just the way I do it now, plus extending the drawer side up into the other volume…
Always wondered if there was another way.
Mark
June 28, 2018 - 5:52 am
Hi Mark,
You can only put drawer boxes into volumes that have parallel top and bottoms.
So to build the box behind a sloped top you must first create a lower volume without the slope by inserting a nil shelf.
Then add a drawer to both volumes. This will create the drawer front without the box. To create the box you click into the lower volume and add a drawer. If you then make the inner box drawer front a nil panel you will have the correct cutting lists.
sloped-drawer.PNGImage Enlarger
sloped-drawer-020.PNGImage Enlarger
Note that although you cannot make a drawer within a sloped topped volume, it is possible to make drawers with sloping sides that fit a sloping sided cabinet.
Hope this is helpful.
mark nichols
Forum Posts: 169
June 27, 2018 - 4:58 pm
Hi All
Does anyone have a workaround for adding a drawer into a slope top cabinet with the internal boxing as well, not just the drawer front?
I do have a workaround, but wondered if anyone else has a better one.
Mark
Currently Online: mark nichols, Patrick Maylor
Guest(s) 62
Christian GLENET
mohammadmaghari
Petru
Trojan Construction
Islam Boukouiren
Topics: 2970
Members: 566
