Sorry at this time there is no solution to have edges together (L/R or T/D) , without extra editing
Cheers, Alexandre
May 18, 2014
I often need to create a cutting list for another supplier to manufacture from. Ideally I would like this to be as quick as possible without the need for any editing after export. One of the main issues I have is that most suppliers do not recognise the edging definition by top, bottom, left, right. They generally define them as long edge and short. Because of this I then need to go through the exported cutting list and edit the edged parts from top, bottom, left, right to either long or short edge.
Is there a way that this can be done without having to edit?
I have attached a PDF cutting list for the main supplier I use. I would ideally like the export to be as close to this as possible.
Kind regards
Tom
