March 20, 2016
Ness said
Hi leo,I'm not very sure that I understand exactly what you are trying to do but you might find it easier to use double backs to build the frame.
I attach a model as an example.
In anycase Polyboard will not be good at face frames until we develop a specific module.
Hi Ness, Sorry for the confusing on the cabinet. I understand that Polyboard currently has a quick fix for face frame. I see what you did on the cabinet. Thank you helping!!!!! What I was trying to get is the face frame stile and the bottom rail increasing them to be flush with the inside of the cabinet, as in the current layout the face frame is flush with outside of the cabinet. Thank you for clarifying, I'll have to wait for when the face frame module will be add in the future.
Leo
Hi leo,
leo d
Hi Leo,
Please post the Polyboard cabinet so that I can have a look at how you set it up.
March 20, 2016
I build a cabinet that is 31 inch tall and 22 width and 12 inch depth. if you look at the picture it shows that the plywood is the same length of the face frame. if the top and bottom of the face frame should be smaller, then that would make the face frame smaller by 3/4 for both, bring a 3/8 inside the cabinet for both side
Hi Leo,
Can you post a drawing with a few dimensions of what you want?
March 20, 2016
If the plywood is 3/4 and the face frame is 1 1/2 making the face frame 3/8 inch from the outside of the plywood, is there a way of create this type face frame for the left and right size of the cabinet? I notices that in the video that the plywood and face frame are the same size, should the plywood be same size of the cabinet not the size of the face frame( 31 cabinet size and face frame 32)?
Hi Leo,
Here are a few videos that show different ways of setting up Face frames in Polyboard.
Note that actually Polyboard doesn't have a real face frame function and these are just work arounds.
We are hoping to publish a version with face frame management later this year.
