First PolyBoard project|Forum|WOOD DESIGNER
Forum Posts: 954
December 20, 2018 - 9:20 am
Hi Deividas, the 2D DXF files are in the sub folders in that zip folder. We don’t offer a nesting optimisation or cutting optimisation service as part of the CabinetFile service. The best way to take a look at output from OptiNest or OptiCut is to go to the bottom of the download pages for each where you can download sample optimisations for testing. Hope that helps, thanks
December 20, 2018 - 8:48 am
Deividas Galminas said
Hi again,
Thank you very much. I will check it
I have few questions. Is it possible to get 2D DXF filse? And is it possible tu get cut plan, like for OptiNEst or OptiCut?
Looking forward for your answer.
December 20, 2018 - 8:11 am
D-Alexandre said
hi again,
here join your files
tel me if you need other or DXf adjust
All the best, Alexandre
(and sorry for my english)
Hi again,
Forum Posts: 2128
December 20, 2018 - 8:08 am
hi again,
December 20, 2018 - 8:03 am
D-Alexandre said
hi,
could you confirm units using?
We using mm
Forum Posts: 2128
December 20, 2018 - 7:57 am
hi,
December 20, 2018 - 7:47 am
I made first my PolyBoard project for test, before we will buy full this software version.
I want to ask you send for me CabinetFile (PDF workshop document, including the cut list and plans, plus DXF files).
Currently Online: LORIN STANCIU
Guest(s) 48
Timothy Bennett
Members: 536
