fitting links not showing on my 3D view on Polyboard|Forum|WOOD DESIGNER
September 22, 2019 - 9:05 am
Alex said
In 3D mode,
Can you control, in menu
3D>Tooling
Or here in Toolbar
Cheers, Alexandre
Thank you, I knew it would be something simple.
Kind regards,
Kirklaugh
September 20, 2019 - 7:13 pm
In 3D mode,
you can control this in the menu
3D>Tooling
3d-Tool.PNGImage Enlarger
Or here in the Toolbar
Cheers, Alexandre
Carole
Forum Posts: 73
September 20, 2019 - 5:12 pm
Hi Kirk,
As you are a Premium Support subscriber, I’ve moved your post to the appropriate forum.
One of our professionals will answer to your query shortly.
Carole
September 19, 2019 - 7:21 pm
Something has happened on polyboard to my fitting links. All of a sudden they are not showing up after I apply them to my designs.
I need to know what fitting links I have applied before I can cut my panels or they might be wrong for the units I am making.
Is there a setting that may have been accidently applied that has turned the images off?
Please help.
Kirk
Guest(s) 17
Topics: 3003
