Fitting Links problem|Forum|WOOD DESIGNER
November 30, 2017 - 4:43 pm
Hello Rafal,
To limit drilling to the smaller under passing panel use a rule that references the under passing panel and not the over passing panel.
In the Quick Design  rules these end in the letter “n” (for non priority panel).
limiting-drilling.pngImage Enlarger
If you use a rule referencing the over passing panel (ending in “p”for priority panel)
The holes or other hardware will follow the dimensions of the other panel:
contiuous-drilling.pngImage Enlarger
November 30, 2017 - 12:04 pm
Rafal Meckovski said
Hello! The back pannel on this cabinet has a huge recess from the bottom and I dont want PolyBoard to generate the fitting links below the bottom of the back panel (see attached image). I know I can manually disable the individual fitting links, but is there a faster way?
Thanks!
fittings-correction.JPGImage Enlarger
November 30, 2017 - 11:48 am
Thanks!
Currently Online: irmantas Dargevicius
Guest(s) 47
Javier Velázquez
sjust
Topics: 2932
Members: 554
