Fitting rules for Lamello - Clamex, Tenso and Divario|Forum|WOOD DESIGNER
Ola svensson
Forum Posts: 100
December 12, 2023 - 8:29 am
Thanks for your reply Alex.
December 11, 2023 - 11:19 pm
In our libraries, the drillings are designed for the use of portable machines with positioners “Lamello CNC Positioning Pins for Zeta P2” ( 251048 ),
For All Clamex systems, it is specific milling with oscillating moves that can’t be done directly with PolyBoard,
But depending on the CNC brand, Polyboard is able to call the CNC Clamex subprogram (macro) if compatible with PolyBoard.
Ola svensson
Forum Posts: 100
December 11, 2023 - 11:43 am
I was wondering how the fitting rule for Lamello Clamex P14 is suppose to work? It seems that it is specified as 5 mm drilling. Here it is supposed to be maching with the Lamello blade. How come it is described as drilled holes? Is it supposed to be just a marker for the position of the cutting?
Regarding Tenso and Divario, does these fittings and tooling exist?
Thanks!
Cheers,
Ola
  • sp_PlupMedia Lamello-Exc-ClamexP14.zip(120 KB)
Guest(s) 42
