framed doors|Forum|WOOD DESIGNER
framed doors
November 12, 2015 - 5:05 pm
Hi Gavn,
I’m not sure what you are trying to do, do you have an example photo or drawing?
If you want to add a moulding to the outer or inner edge of the frames there’s no way to do this.
Polyboard only works with rectangular sections.
You can always export the DXF files to SketchUp or CAD and add the mouldings but you wont have the prices directly in Polyboard.
The way to get pricing for moulded frames is to calculate the price per meter of the bars with mouldings, grooves etc. This should give an accurate finished price as Polyboard will give you the total length of bars in the project.
Hope this is helpful,
November 11, 2015 - 8:23 pm
HI Ness
wondered if you could help and point me in the right direction with regards to framed doors within polyboard, I know I can set up the door assembly to achieve the basic parts required for a shaker style door but is there any way to add machined edges to the frame so I can add costs to this when setting up the doors.
Guest(s) 29
