I think it has been resolved. Thanks for your comment!
Dennis
December 7, 2020 - 12:38 pm
If I have to machine a vertical partition wall on both sides, then I have a deviation of 5 mm on
the 2nd side because 5 mm was milled off when machining the 1st side.
Regards Dennis
Hi, Is it possible to give the 2nd panel an offset for a panel that is processed on 2 sides? The reason for this is that the panel is cut 5 mm in the 1st operation.
