Groove for LED|Forum|WOOD DESIGNER
You can “Edit…” part and “Add the Structure to the library…”
and after you can set into “Materials Style”
That works for all edition types, I think that can help you for this post
Try to delete and add a fixed shelf from the attached files
Cheers,
May 18, 2014
OfflineHello,
I would like to add a groove and an aluminium track (fitting) to the underside of a shelf (mulitple). I would also require a hole in each side of the overpassing side panel (for cables to pass through).I have started to do this using single panel fittings, however having made the groove I’m now thinking there must be another/ better way to achieve what I need using a similar procedure to that of a hanging rail? Therefore I would when adding a shelf, select a shelf specifically for the led cut out and channel. The groove in the underside of the shelf, the aluminium track and the required holes would all be added….?
Please can I ask if this is the best way and if so the full procedure to do it? If there is a better way then please could I have details on this?
I have attached the model I’m currently working on.
Kind regards
