Halved Joint Divisions|Forum|WOOD DESIGNER
Blake Simpson
Forum Posts: 104
January 17, 2022 - 10:51 pm
Great Thanks
January 17, 2022 - 6:35 am
Hi Stu,
first, add the shelves. Select the complete volume and add half joinet division. Now the shelves are cut in the back. So the order of applying will give you the result you need.
Blake Simpson
Forum Posts: 104
January 17, 2022 - 2:02 am
Hi Team
With using Halved Joint Divisions is there any way of changing halved joint so the fixed shelf is not checked out in the front.
see attached cabinet – we require the shelf to be supported by the division in the front not the back so reversing the halved joints
Dave
Guest(s) 54
brendan kavanagh: 236
Emmanuel Sacco: 210
Zaheer Abbas: 201
Tom Jackson: 142
Rooms Made Simple: 132
MobLux
Valentin Zarzara
Kendal Anderson
Sarah J0hnson
Andreas Nygårds
Nicolas LEBRETON ROOST
Luka Savić
Lee Gent
A S Brighton
Tobias Briander
Topics: 3062
Members: 602
