Hinges Vanished out of Projects and models|Forum|WOOD DESIGNER
Patrick Maylor
Forum Posts: 84
May 3, 2023
May 3, 2023
Hi ALex
They are not there in any mode and they were visible last night as had to shift many of them up and down around shelves. The regular drilling for the adjustable shelf supports have disappeared also. All that is now visible are the Cabineo in the 3D wire frame. The holes appear to be in the cutting sheet diagrams and lists, but obviously I need to see where they are in the wire frame to make sure thay are not interfering with shellves.
Cheers
Forum Posts: 1964
Only 3D accessories are visible in project mode,
If they are in the Cutlist, It should be okay, in case of doubt you need to open the cabinet and then check from the cabinet mode.
Most Users Ever Online: 365
Guest(s) 24
brendan kavanagh: 179
Tom Cleaver: 164
mark nichols: 162
Conor Devoy: 158
Zaheer Abbas: 132
Blake Simpson: 104
Patrick Maylor: 84
Tom Jackson: 83
Rick48
Hassan Sultan
Carmela Di Sorbo
Telmo Oliveira
Jesus Vergel
eduardo beiza
lucas Lucas Moreno
Efthimis Stathas
Rayallie
Topics: 2513
Members: 393
© Simple:Press —
