holes for runners missing |Forum|WOOD DESIGNER
August 6, 2021 - 3:40 pm
Hi Josh,
Here is a reply from the developers confirming an issue
We analyzed the Customer’s cabinet, and we do confirm that the unboxing
has an unwanted effect, but only on the lower drawer.
We have fixed this bug in our internal source files, and the final fixing will be
available in the next release, after the holiday period.
After the fixing: the lower drawer starts 15 mm below, but the upper drawers are unchanged and the slider positions
are as defined by the settings.
Therefore if your Customer has an issue with the upper drawer sliders, then
he should review his settings (synchronizing zones and rules references, etc.).
August 6, 2021 - 8:39 am
Hi Josh,
The issue could be originating from the unboxing feature. I have informed the developers and wait for their reply
August 6, 2021 - 8:03 am
Hi Josh,
Sorry for the late reply.
You are using the tandembox slider so it could be that there was a box reference error. Can you check if this one is now correct?
josh hallahan
Forum Posts: 6
July 21, 2021 - 12:13 pm
Hi Michael, the holes for the runners on the top three drawers are 15mm to low when I make all the draws the same size.
July 21, 2021 - 11:01 am
Hi Josh,
I do not see any problem with this model. Is this a corrected one? If so please send me the original one with the problem
josh hallahan
Forum Posts: 6
July 21, 2021 - 10:03 am
Hi Michel,
Thanks for this. I have another problem with the drawers. the position of the first draw is correct but the three drawers above where 15mm to low. I’ll attach the file for this. I also had a similar problem when I fitted the previous job with the built in drawers which is the file I sent you last time.
I’m also having problems with the axis speed when routing on my vitap cnc. I changed it on the tpa post processor but the machine does not read it but does read it when sawing. Also is there a way to change the entry speed?
many thanks,
Josh
June 14, 2021 - 6:38 am
Hi Josh,
Here a small video to explain the problem with your slider holes
josh hallahan
Forum Posts: 6
June 2, 2021 - 12:59 pm
Hi Michel,
would it be possible to do a video call to explain it?
thanks,
josh
June 2, 2021 - 12:03 pm
Hi Josh,
you have to change your fitting link rule for the drawers
begin reference needs to point to zone inside instead of overpassing. This will patch the holes for all drawers
josh hallahan
Forum Posts: 6
June 1, 2021 - 8:57 am
Hi Michel,
Have you had a chance to look at this?
Thanks,
Josh
Guest(s) 26
Topics: 3003
