Home Office Built-in Desk and Bookshelf with grey natural wood Veneer |Forum|WOOD DESIGNER
June 15, 2015 - 6:15 am
Hello Alan,
Thanks for posting your project on the forum.
Here is a quick model of you project.
I’m not sure that I have understood correctly how the modules fit together, but in the configuration I’ve set up the “pass cables” under the desk 01 will stop the doors of desk 02 opening.
Before building this you’ll have to look at how you want the backs to assemble and what hardware you’ll use for doors and drawers.
You can play with this design to set it up to your needs and we can send you your free plans cutting lists.
If you need more advise and a complete revision of your final project you can buy the CabinetFile Pro service.
project-3d01.jpgImage Enlarger
June 14, 2015 - 8:45 pm
Hi, I’m new to the PolyBoard Software and would love is someone can give me a jump start!  On the site it says “for a limited time only we are offering to set up your furniture or stair design for you.”
Below are the drawings with dimensions in mm someone did for me once but is was way to expensive.  It is almost exactly what I want to do.  The idea is to build it with 20mm MDF boards (that is the thickest I can get here) that I would have to sandwich two of them to make the 40mm.  The surface will be a Grey natural wood Veneer that I would glue on after getting the boards cut at the local shop.
Some of the doors on the furniture would be a sand blasted glass to give it a modern look and that hides the inside.
Thank you for helpingIMG_1520-3.PNGImage Enlarger
IMG_1518-3.PNGImage Enlarger
IMG_1519-3.PNGImage Enlarger
Guest(s) 22
Topics: 3003
