In frame design for shaker doors|Forum|WOOD DESIGNER
Have you try to work with external zone?
Then add double-back from frontage a 0mm, then overpassing double-back on Side,bottom and Top
This solution allow to work, like classic cabinet
The external zone define width,
it possible to work with assembly but this solution is hardest to managed, but it was the only solution in previous version (sample cabinet joined with this old solution)
Hi Alex,
I have come to do my first shaker sale kitchen in polyboard and need some reminders…
How do I create the hardwood face frame on a cabinet for in frame doors and drawers….I think I can do the doors OK.
The face frame consists of 45mm wide bottom and side pieces and a 35mm top piece. (both 25mm thick). The Frame will protrude outside the width of the cabinet.
Thanks, Oli
