Inset Door Issue|Forum|WOOD DESIGNER
I think these two videos can help you to explain and complete what you need for doors
and
All the best, Alexandre
November 15, 2018
Hi Richard,
Thank you for using our forum. As a Premium Support member, you have access to the technical section of the forum, which is where I have moved your post.
A member of our technical team will reply to you as soon as possible.
Have a lovely day! 🙂
Hi. I am trying to build a series of cabinets, all with inset door detailing. However when trying to set the overpassing/underpassing I am only able to change the panels above and beneath the door, with the option to change the sides greyed out. I imagine this is something to do with the hinges and not allowing it? But i’m not sure.
Please see the attached file to understand better where I am now.
Any help would be greatly appreciated. Thanks!
