Issue with inset doors|Forum|WOOD DESIGNER
We are having a few issues with applying fittings on a simple cabinet, some of the fittings are not working as we would expect.
The back panels has been set the drill a 5mm hole where it over passes a fixed shelf to vertical divider. The vertical dividers are not inline vertically and it is placing the line of screws holes from the top to the bottom of the unit not from the top to the bottom of the vertical divider. See attached image.
We are also struggling with using inset doors on the same project. I think it will be the same issue but are unsure how to solve it. It is placing the hinge position not in relation to the doors but in relation to the carcass. For example it is putting a hinge at the top and bottom of the side panel not at the top and bottom of the door. Again see image attached.
I have also attached the PB file
