Click here for the video on how to set up the horizontal rails for presentation purposes.
As I say in the video this method gives a reasonable visual of the rails but the notched uprights are not correctly marked out.
I’m shooting another video that shows how to set up the notches as hardware.
Like that using a manufacturing method will place the rail notches automatically each time you set up drawers and you wont have to calculate the rail positions.
Click here for the video on vertical handles profiles.
I’ll shoot a video for the oven, but while waiting have you seen the other accessory type videos like the TV, aquarium and cookers (click the links below for each):
This is great idea, for a Polyboard project and I’d love to help you on this.
It will certainly be interesting for me as I’m not too savey in kitchen design.
I’ll shoot a couple of video to show how to do the plinths, handles and side panels.
For the appliances can you give me the models that you want to show and I’ll set them up for you.
If you can tell me how you assemble the cabinets and some general info on the design, materials hardware etc, I could set you up a few manufacturing methods that might make things easier.
I’m uploading the first video now so should be online in an hour or so.
Need to work out how to make the plinth overpass the carcase so it looks contiuos (no gaps) without having to make a seperate item.
How to do the handle profiles…
How to add and end facing panel that hides the side of a unit.
How to make an appliance like oven or hob and sink and tap.
Jimbo
June 20, 2014 - 5:26 pm
terry said
Best of luck with that Jim. I would be more than interested in seeing something like this. I have fitted a few kitchen (ikea, magnets etc) but would really like to get set up to make hand made kitchens. All in good time. Interesting post. Thanks Jim.
Terry
Cool! Thanks for the encouragement Terry,
Heres a link to the drawing I was sent to work from for the the main elevation.
Not very easy to make much sense of, but the basic info is there now to try and do it as a polyboard project.
June 20, 2014 - 4:56 pm
Terry
June 20, 2014 - 4:47 pm
I have recently been instructed by an architect I have worked with previously to build a kitchen for a clients project he is working on. The client has done some rough sketches which they have asked me to turn into a kitchen. So I decided to try and make this my first full and propper polyboard job. By that I mean designing it with full details (no dodgy workarounds) and produce the full cutting list rather than manually checking or adding bits I was unable to design. I also need to make the drawings good enough to present to a client and architect!
Next I will document the build, showing how we normally construct cabinets and any specialist fittings we use on this job (there will be a few, sliding doors is one) as well as info on a corian solid surface worktop. There are also specialist finishes involved, gloss spray finish and concreate effect doors and drawer fronts.
Finally (not till sept) I will show the installation and final finished result!
