Lead-in for biesse nesting|Forum|WOOD DESIGNER
July 25, 2022 - 3:33 pm
Hi Krit,
The latest version 7.08g contains a new lead-in called “3D Arc 45” specifically for the nesting mode.
Please update your software with this link and run some tests
revert to confirm if it is working as you expect it otherwise we will need further explanations from you.
Krit Rojanarungruengporn
Forum Posts: 6
July 25, 2022 - 6:21 am
I have a problem with the nesting application [Polyboard export to Bnest]. I saw that ,in the postprocessor option, there are lead-in options in profiling section, and I have tried some of the options but I can’t make it to go 45 degree in XZ or XY planes. The 45 degree line only do it in XY plane which can’t be used in nesting. Can you suggest us how to export the files with 45 degree tool lead-in in XZ or XY plane.
Guest(s) 29
