Legra box height|Forum|WOOD DESIGNER
Legra box height
dsdds
Forum Posts: 16
January 8, 2024 - 7:29 pm
Perfect.
Thank you. Yes it was the back of the box that was worrying me. I set them all to M. The only strange feature I found is when doing individual drawers with nil shelf divisions, the gap between the drawer fronts (top and bottom) seemed bigger in the rendering. I oversized them and that seems to have fixed the issue. Weirdly I could not specify M sized drawers as a 4 drawer set. I could do K but M i had to do individually.
January 7, 2024 - 10:13 am
Here is a short video to explain, as your dimensions are not the ones used to build the drawer in PolyBoard. Hope this will clarify everything
dsdds
Forum Posts: 16
January 6, 2024 - 8:10 pm
Hello.
Sorry. Please take a look at the attachment picture.I would like to know how to specify these heights. Also I have included the design.legrabox.jpgImage Enlarger
January 6, 2024 - 5:19 pm
Can you be more specific in your request? This is not very clear.
We have the Legrabox drawers set up in our libraries with alternatively all other heights, which can be called using the DRAWERS Gen Mat if different heights are needed in the same cabinet.
Can you also add your cabinet file in this regard
dsdds
Forum Posts: 16
January 5, 2024 - 9:29 pm
Hello.
If doing cabinet boxes out of the blum legrabox system can you please tell me how to set the letter heights for the boxes in the software. I think this has en effect on the back of the box and subsequently the panel part I need to generate.
Thank you.
Guest(s) 32
