Libra H2 cabinet hanging system|Forum|WOOD DESIGNER
If I understand correctly, you used 37-n to refer to a non-priority pannel (Underpassing).
But here underpassing panel is cabinet back + Groove, the fitting are made from top at 37 less 10mm , 27mm
And you have to use 37mm of inner zone, conventional from top to bottom.
For the material,
the drillings assuming that the first hole is placed at 0 so at 37mm with the ruler no problem
For the shape
From the side panel, consider the recess as NO, you can check the tow option to see the difference in the starting references (red arrow).
From the top, from the right, centre at 37mm with the ruler minus 3mm to finish at 34mm.
X -3mm Y 19.5
Sorry for my english hope this is quite clear
Guest(s) 34
© Simple:Press —
