Living Room Project|Forum|WOOD DESIGNER
Hi Craig,
I hope you have had a great Christmas and New Year celebration.
Before I process you project here are a few questions:
– you have no edging on your panels, is this correct
– there is no hardware nor assembly details, would you like some help to set these up?
– the project is built using default Quick Design materials, it would probably be better to apply materials that fit those available in your area.
– can you tell me if you need the cutting lists in inches or millimeters?
If you tell us how you are going to build the project and what materials you want to use we can set your project up correctly for manufacturing.
If you want to do this yourself look at the Quick Design advanced videos here:
https://wooddesigner.org/membe…..-advanced/
