Multiple orientation for intermediate cross bars|Forum|WOOD DESIGNER
Hi Tom,
There is a solution with the assembly and it will give you a full visual
The closest solution would be:
– To apply a first assembly level with a single intermediate cross-bar,
– To create a second assembly level to one of the sub-panels with a single
intermediate cross-bar rotated by 90°, and to apply a nil material to all
other bars except for the intermediate cross-bar.
You would get a full visual solution, and a partial assembly solution (the assembly
of the last intermediate cross-ar would not be handled).
See attached cabinet
Hi Tom,
You can add an intermediate cross-bar. You need to display the advanced parameters. This will add an orientation field for the intermediate cross-bar. However, it is not possible to give separate orientations to multiple cross-bars. The design on your picture is not possible with an assembly. I will inform the developers to see if this could be an addition to the assembly.
If you use a regular panel door you can create that visual using inner toolings.
May 18, 2014
I am wanting to make a door panel with both a horizontal and vertical intermediate cross bar. I can’t seem to find an option to allow intermediate cross bars to have different orientations. Is there a way to do this? I have attached an image showing the upper doors that I am trying to achieve.
Kind regards
Tom
