over sizing issue |Forum|WOOD DESIGNER
Yes, From Post-Pro Option,
We recommend duplicating your Post-Pro first
reminder,
Net Dimensions = Panel – Edge thickness + Over-Size
Overall Dimensions = finished panel size.
If you do not want the net dimensions to be deducted from the edge thickness, you must set the edge thickness to 0 mm in the edge material libraries.
Guest(s) 24
© Simple:Press —
