Oversize not working with faceframe|Forum|WOOD DESIGNER
OfflineHi Tom,
Also, this issue was solved in version 7.10s from which I sent you the link in an earlier post today.
Forum Posts: 2128
After test it look there is well bug here,
When you add double back through side, Over sizing look to be forced to sub-methods setting
The time I forward this issue to dev team and get have better solution, you can make oversize parts with sub-method
(PS in case of setting part into “though” tab here with side you don’t need to add recess from frontage too)
Currently Online: LORIN STANCIU
Guest(s) 16
Javier Velázquez
sjust
Topics: 2933
Members: 554
© Simple:Press —
