Panel Material with different textures on face1 and face2|Forum|WOOD DESIGNER
Forum Posts: 1921
April 25, 2024 - 8:02 am
Please find video to show process
Structure can be save into Structure libraries
Panel design
Pravara Modular Industries LLP
Forum Posts: 17
March 6, 2024
April 24, 2024 - 12:39 pm
I have checked the training video regarding thickness split. I will try the same and let you know if I have any more questions.
Thank You,
Venugopal N.
Forum Posts: 17
March 6, 2024
April 24, 2024 - 12:08 pm
Can you please elaborate on surface split a bit more?
Thanks & Regards,
Venugopal N.
Forum Posts: 367
April 24, 2024 - 11:57 am
Hi Venugopal N.
You can use a thickness split if you want to have a veneer face on the panel, this is a solution for this. You could use a similar method if you just wanted a “visual” for an image.
Please note that you cannot create a panel material that has two different coloured faces/textures on Polyboard.
Forum Posts: 17
March 6, 2024
April 24, 2024 - 11:50 am
We work with plywood and laminates. We generally use 2 different panel materials.
1, Both faces with same texture.
2, Both faces with different textures.
Even cabinet doors we use two different skins on either sides. For manufacturing I can select a different material and proceed. But this workaround will not help me with my client presentations.
Now, I don’t understand how to proceed with this requirement.
MITC
Forum Posts: 60
October 3, 2022
April 24, 2024 - 9:57 am
Do a thickness split – one of the materials could be very very thin so it wouldnt effect the CNC output. But would visually look like a different colour it you set it as that in the materials.
Forum Posts: 367
April 24, 2024 - 8:26 am
Hi Venugopal,
Currently there is no way to visually assign multiple colours/textures to a panel material on PolyBoard.
Let me know if there is anything else I can help with.
Forum Posts: 17
March 6, 2024
April 24, 2024 - 8:03 am
I’m new to Polyboard. I have a requirement to create a “Panel Material” with different textures on both the faces. i.e on face1 should have colour1 and face2 should have colour2. Please let me know how to create such panel material?
Thanks & Regards
Venugopal N.
Most Users Ever Online: 365
Guest(s) 17
Tom Cleaver: 164
brendan kavanagh: 156
Conor Devoy: 146
Zaheer Abbas: 122
Blake Simpson: 104
Robert Coxhead: 74
Patrick Maylor: 74
Andrej Potočnik
Olga Safari
Greg Allen
Maximo Vinet
ben levene
roni ben ami
Kateryna Druzenko
Joseph El Hajj Moussa
razvan george tomas
Dennis Nwachukwu
Topics: 2345
Members: 350
