Peanut Wrong start point |Forum|WOOD DESIGNER
Forum Posts: 2110
December 15, 2023 - 1:59 pm
Thanks for this feedback,
nathan cassidy
Forum Posts: 4
December 15, 2023 - 12:18 pm
HI Alex
I done as you said and it didn’t work. But I did get it in the end.
Just in case anyone else has this issue what I done was:
Library – Fittings – Intelligent fixings – 1/3d. Then I clicked the overpassing for the slot cutter. Click orientation which mine was set at 0* and I flipped it 180*. Now it imports into V carve correctly.
Forum Posts: 2110
December 14, 2023 - 10:00 am
Sorry for this late reply,
Depending on your setting, the default shape used by this fitting, use the inner tooling of your PP configuration.
You can reverse it from your PP setup.
Ori.pngImage Enlarger
nathan cassidy
Forum Posts: 4
December 11, 2023 - 9:32 am
No Problem
Please see below.
Forum Posts: 2110
December 11, 2023 - 9:25 am
Hi again,
Sorry for my lack of clarity, but can you attach the DXF output from PP and the PolyBoard cabinet file (*.pb-cab)?
Then I see as soon as possible with my collègue Michel
nathan cassidy
Forum Posts: 4
December 11, 2023 - 8:16 am
Hi Alex
Thanks for getting back so quick.
Please see attached.
Thanks Nathan
Forum Posts: 2110
December 11, 2023 - 7:51 am
Can you upload PolyBoard DXF and project?
nathan cassidy
Forum Posts: 4
December 10, 2023 - 6:12 pm
Hi
I am new to polyboard and vcarve.
I am using Peanut 1 in my cabinet build. When I export polyboard – opti-nest – V-carve and I assign my tool path for the peanut cutter slots all the start points are wrong. I know I can reverse/change start point but is there an easier way to rectify this issue?
I have attached a picture below for reference
Thanks Nathan
Guest(s) 75
Emmanuel Sacco: 179
Zaheer Abbas: 175
Tom Jackson: 133
Beth Hinks
Manuel Belmar
Colin Rouse
Steven mason
Chas Joy
Eduardo Montilla
Mounib osman
Sebastian M.
Tom McGranaghan
Mohamed Mekayed
Topics: 2874
Members: 522
