When placing a plinth on a design and applying a mortise and tenon joint to the left and the right side. The mortise is full length even if you reduce the shoulders to allow for this.
However, if you change the plinth to a double back in the same position, the mortise will be the correct length with shoulders added.
This does not seem to happen with any other panel, just the plinth. Although I haven’t tested all panels.
