post for biesse|Forum|WOOD DESIGNER
post for biesse
August 29, 2023 - 7:59 am
> when chamfering / mitrecuts with the sawblade, we cannot control the direction and lead in, this is essential for the job
– What is the problem encountered?
– What is the precise request, and does it relate to the parameters illustrated below?
available for grooves but not for chamfers?
grooves-para.pngImage Enlarger
> drilling operations when a drillchange is required (hinge boring) the drill plunges down to early and destroys the board
– We don’t understand where the problem illustrated in the video comes from,because unless we’ve forgotten, there is no approach option for drilling.
– Have you already made test in milling mode?
milling-drilling.pngImage Enlarger
– Can contact Biesse to look if it have specific constraint with your machine?
Cheers, Alexandre
August 22, 2023 - 2:32 pm
Files received, I have send you direct mail
torkild sckerl
Forum Posts: 42
August 22, 2023 - 2:22 pm
sorry forgot , we are using polyboard ver. 7.10
T
torkild sckerl
Forum Posts: 42
August 22, 2023 - 2:21 pm
Hi Alex
Thank you,
reg T
  • sp_PlupMedia mitre-test.zip(45 KB)
August 21, 2023 - 9:38 pm
Can you let us know which version of PolyBoard are you using?
Can upload cabinet used for this test?
– drilling for dowel perpendicular to the surface is not working in the post
> You mean Vertical drilling? or Horizontal (edge) drilling
– when chamfering / mitrecuts with the sawblade, we cannot control the direction and lead in, this is essential for the job
– drilling operations when a drillchange is required (hinge boring) the drill plunges down to early and destroys the board
for all case ,can you upload:
> original CIX PolyBoard export and edit CIX working on your CNC
> or CIX working programme write directly from Biesse software
torkild sckerl
Forum Posts: 42
August 21, 2023 - 4:41 pm
Hi
We are having a lot of trouble with the postprocessor.
Attached
video link for simulation of drilling issues                          [Subscribe to Premium Support to view this media]
postprocessor for our biesse rover 5axis cnc
regards Torkild Sckerl
baarup furniture
Guest(s) 49
brendan kavanagh: 236
Emmanuel Sacco: 210
Zaheer Abbas: 201
Tom Jackson: 142
Rooms Made Simple: 132
MobLux
Valentin Zarzara
Kendal Anderson
Sarah J0hnson
Andreas Nygårds
Nicolas LEBRETON ROOST
Luka Savić
Lee Gent
A S Brighton
Tobias Briander
Topics: 3062
Members: 602
