Post proccesor Option - Ungroup Drill face 1 and face 2|Forum|WOOD DESIGNER
May 12, 2020 - 10:59 am
Hi Hung,
I think I have perfectly understood your question.
The 2 options in the Optinest pp refer to the way holes are drilled.
When a part has a hole on each face that align, “Opposite Drillings” either will maintain 2 holes (one on each face) or create 1 hole that goes through the part.
The Optinest pp will flip parts so that the machined faces are upper most. If a part has a hole that goes through from one face to the other “Through drillings” can put the drilling face onto the upper nested  face even if it has be set in Polyboard on the under face.
In both cases using the Optinest pp both faces will be exported into the same drawing.
When a cabinet panel has 2 separate machine operations on each panel face, you must not use the Optinest pp.
Instead use the DXF pp and set the “Tooled faces export” function to “One exported file per face”.
tooled-faces.jpgImage Enlarger
You will then have a folder with all the machined faces. Take out of the folder the second face of the double faced parts and load the remaining parts into Optinest.
This will create the nesting maps for all the parts but the double sided parts will only have one face machined.
Put the double sided parts back on the machine upside down.
Create some machine files with the second face DXF files and run them on the second face of the parts.
Hope this is helpful.
May 11, 2020 - 11:25 pm
Dear Ness,
 Maybe you don’t understand me. I can explain clearly: I need function to separate the face in post processor when export from POlyboard to OPtinest (not to DXF). I have just exported to DXF from OPtinest (after nesting on panel), because My CNC machine use different software to set toolpath (can not PP direct from Polyboard).
 Can you show me about 2 option on this pic. Thanks
PP.PNGImage Enlarger
May 11, 2020 - 10:30 pm
Dear Ness,
 Your mean: can not export direct to optinest if want to separate the faces. Have just use export DXF file then import DXF file to Optinest?
May 11, 2020 - 6:45 pm
Hi Hung,
To separate the faces when using DXF to Optinest you must  not use the Optinest pp export.
Instead use the standard DXF part by part export and import only the faces to be nested.
May 10, 2020 - 8:27 am
Dear,
I have problem when Post proccesor export (Optinest-Bsolid) – The upright drill 2 Face have group all drill on same face ==> Export DXF file for set toolpath all drill are wrong. Please show me how set Post proccesor option? to separate face by face drilling
ThanksTest-drill-2face.PNGImage Enlarger
Group-same-face.PNGImage Enlarger
Guest(s) 52
brendan kavanagh: 236
Emmanuel Sacco: 210
Zaheer Abbas: 201
Tom Jackson: 142
Rooms Made Simple: 132
MobLux
Valentin Zarzara
Kendal Anderson
Sarah J0hnson
Andreas Nygårds
Nicolas LEBRETON ROOST
Luka Savić
Lee Gent
A S Brighton
Tobias Briander
Topics: 3062
Members: 602
