Setting internal faces for Z/wall@model|Forum|WOOD DESIGNER
Forum Posts: 1959
Hi, there,
for the particular pieces we already use a cabinet function
The first solution is to not use Bottom of cabinet by setting it to No/Nil panel and create floor from project mode to drop your cabinet on this floor
The second solution consists of defining a thin wall with a material 0.01 mm thick
Patrick Maylor
Forum Posts: 81
May 3, 2023
May 3, 2023
Good morning
I created a room using z/wall@model. As it effectively a cabinet, when I add units into the space it uses the outside face as the reference for the quick positioning whereas being a room I need them to use the inside face. Is there a way to make the inner surface the reference as I have tried a nil panel and everything else I can think of but with no success?
Patrick
Most Users Ever Online: 365
Guest(s) 17
brendan kavanagh: 165
Tom Cleaver: 164
mark nichols: 162
Conor Devoy: 158
Zaheer Abbas: 132
Blake Simpson: 104
Tom Jackson: 83
Patrick Maylor: 81
Miryahya Khameneh
mathew moule
Christian Lopardo
Romerworld
Evaldas Gudenas
Petr Břichnáč
Ar Te
Ilie Mihail
GERARDO MARMOLEJO
Salman Bukhari
Topics: 2478
Members: 379
© Simple:Press —
