Shaker doors|Forum|WOOD DESIGNER
Shaker doors
Forum Posts: 2128
July 12, 2023 - 12:40 pm
There is currently no parametric solution with inner tooling.
dean price
Forum Posts: 56
July 12, 2023 - 8:36 am
HI Alex
Thanks for the reply, is it possible to do this method which is parametric , the same way a structured panel assembly doors-1.JPGImage Enlarger
would be with intermediates and stiles
Forum Posts: 2128
July 11, 2023 - 7:28 am
This video is an example of full processing,
But you can apply the internal tool to draw shapes,
inner.pngImage Enlarger
Then, in Vcarve, select the shapes and apply the pockets.
poket.pngImage Enlarger
Be careful, if the depth is too pronounced, remember to carry out the same machining on the reverse side, otherwise this will unbalance the forces on the face and when painting it will have a banana effect.
I’ve already been fooled by standard MDF, so I recommend high-density MDF.
dean price
Forum Posts: 56
July 10, 2023 - 8:30 pm
Hi Alex
Thanks for the video , i have give this a try but when i ouput to vcarve it creates multiple dxf files for each component and not one single panel.
is this possible to create a single panel output of a shaker door with mid rails  like the photo attached??
Hope this makes sense
Many Thanks
Dean
doors.JPGImage Enlarger
Forum Posts: 2128
July 10, 2023 - 7:41 am
This video should helpful,
dean price
Forum Posts: 56
July 9, 2023 - 8:55 pm
Hi ,
I have made the shaker doors on this cabinet using inner tooling but would like to be able add rails and make it a library structure  if that is possible please.
i am wanting this method so i can output it as a single panel to cnc out the inner tooling section and create a shaker look alike.
Hope this is possible
Many Thanks
Dean
Guest(s) 42
brendan kavanagh: 227
Emmanuel Sacco: 196
polyjohn
Maxime Marengere
everslyjoinery
Topics: 2903
Members: 539
