When using multiple box cabinets it is a real pain when you have to have one for a left hand filler, end panel or just need the full gap (left and right). Then one for having no gap (left and right). And that is just one facade design so then you need that combination in a door, drawer (multiple combinations!) ect………
There must be a way to set this up? Many other kitchen software has this.
Jason
Forum Posts: 1758
Subscriber Since: January 20, 2017
Offline
August 11, 2020 - 1:14 pm
Shared slack is only applicable when you add doors / drawers on the same cabinet.
It’s why my personal set up in sub-methods is 1.5mm around the cab and 3mm between faces, when you’ve joined them, that gives 3mm too.
