Sloping cabinet with drawers|Forum|WOOD DESIGNER
OfflineHi Tom,
can you try this solution?
Hope that’s helpful!
Cheers, Alexandre
May 18, 2014
OfflineHi Alex,
That’s disappointing to hear for a cabinet that is fairly common (understairs storage). Is there not another way to create a drawer in a sloping cabinet (not using a nil shelf)? It seems strange that polyboard can’t create a drawer for this type of application.
Tom
Sorry it took me a while to understand your cabinet,
the solution you use with nil shelves creates this issue,
I think you have reached the limits of Polyboard on this point
OfflineOk so now I seem to have an issue with the drawer front. There doesn’t seem to be the option for me to overlay the right hand side of each drawer front. I can overlay the left but not the right. These are built in drawers but need to overlay the vertical partitions. This is not a problem I have encountered when doing the same thing with doors. Please see attached.![]()
OfflineHi Tom,
Maybe you can try this (EDIT: image removed),
1 Mortise & Tenon with a top
2 Then add a Surface split
Cheers, Alexandre
May 18, 2014
OfflineHi Jan,
Thanks for the reply, however this is not really what I am looking to achieve. Ideally this would be a pull out drawer, such as a pull out larder in a kitchen unit.
I managed to get the drawer created by adding a nil shelf 1mm from the top. I then created some inner tooling for the cut outs on 1 side. What I would like now is to have the other side full height (higher than the side with the inner tooling).
Kind regards
Tom
