Top Overpassing doors|Forum|WOOD DESIGNER
Forum Posts: 2128
August 24, 2023 - 6:58 am
Hi Patrick,
There is 2 case,
First case with single door, It’s still very simple, just change the priority of the link to the top.
Global-Door.pngImage Enlarger
Second case, you have upright!cry this option are locked!
door-with-up.pngImage Enlarger
But, now when you add news option when add frontage! “Applied local” , which means that only rooms in the area where the facade is added will be recessed.
Applied-door.pngImage Enlarger
Like in this example, Left side, Bottom, and Top, are part of the area where the door was added,
The side on the right reaches the same level as the door.
if you’re building a TV cabinet, for example, with several uprights
add Nil shelves on each zone at 0 mm from Top, then add frontage doors / drawers in “Applied mode”
add-nil.pngImage Enlarger
nil-shelves.pngImage Enlarger
Hope that’s helpful, Alexandre
Patrick Maylor
Forum Posts: 120
August 23, 2023 - 3:59 pm
Hi
I keep coming up against the same issue when I put an overpassing top and I cannot change the doors to under passing the top.  I have searched and tried all I can, so can you let me know how I get this to work?
Currently Online: Isaac, LORIN STANCIU
Guest(s) 37
Timothy Bennett
Members: 536
