upper strips|Forum|WOOD DESIGNER
upper strips
Conor Devoy
Forum Posts: 174
November 28, 2022 - 3:50 pm
Got it, thank you.
November 28, 2022 - 2:10 pm
Yes,
The total height of the cabinet, including doors, should be 2580 mm.
Conor Devoy
Forum Posts: 174
November 28, 2022 - 1:07 pm
Hi Alex,
I tried again and when I put -20 on top 1 and top 2 it does overpass the top y 20 but it does it by reducing the height of the cabinet.
Do I have to increase the height of my cabinet and then add the doors then overpass the cabinet with the doors reducing the cabinet back down.
If this is the case does the angle stay the same?
Regards and thanks,
Conor
November 25, 2022 - 10:52 am
Hi Conor,
When manufacturing a Multi-Slope top, the overall dimension must always be considered.
With your doors overpassing, that’s changing intersection position
Multi.pngImage Enlarger
doors.pngImage Enlarger
and it is then the overall height to be taken into consideration
2590-30+20
Hope that’s helpful, Alex.
Conor Devoy
Forum Posts: 174
November 22, 2022 - 5:39 pm
Hi, I have a series of four cabinets under a stairs starting with a square topped cabinet and three more with sloped tops.
On the square top I have a 30mm upper strip but I don’t seem to be able to put the top strip on the sloped cabinets.
My problem is I want to extend the doors upwards 20mm higher than the cabinets.
This is ok on the square topped cabinet as I have the 30mm strip to extend into however when I extend above the sloped cabinets it reduces the overall height of the cabinets by 20mm.
I tried to extend the sloped cabinet height by 20mm, add the door and overpass the cabinet with the door by 20mm but my gables don’t match the original and my surface splits don’t line up either.
Is there a way to do what I want i.e. 30mm upper strips on the sloped cabinets or doors 20mm higher than the cabinet without changing the cabinets?
Regards and thanks,
Conor
Guest(s) 49
brendan kavanagh: 236
Emmanuel Sacco: 210
Zaheer Abbas: 201
Tom Jackson: 142
Rooms Made Simple: 132
MobLux
Valentin Zarzara
Kendal Anderson
Sarah J0hnson
Andreas Nygårds
Nicolas LEBRETON ROOST
Luka Savić
Lee Gent
A S Brighton
Tobias Briander
Topics: 3062
Members: 602
